Hi, with the lastest free premium passes i had finally got my 1% chance of winning my current secret missions and now i have 6/7 of the secret set armour.
All that's left is to unlock the last secret from the 10 OB wins of juvisy to get judica's revival mission.
and so here's the Q. Would like to know everyone's suggestion on how to get my juvisy to 100 wins. (remember that juvisy has no good weapon but only bad with swords).
I do have quite a few bodies at my disposal but cores wise i'm heavily lack of gems.
Would magical stick do the work? i do know that at higher level magic stick will not be as powerful.
and, when's the best time to get to EX for best wins.(i am thinking of turning her EX once she' 50. *all the class C kicked outs)
Juvisy 100 wins
Re: Juvisy 100 wins
Not quite sure if you get this one already, but here is what I think it may help you to get there...
1. Fight rank C with dual dagger harvester build. (10 wins should be no problem.)
2. Fight rank B while moving towards high attack/accuracy build. (Jump to rank EX if you can't win, or jump to rank EX when you get to rank A.)
3. Max out as high attack/accuracy build, fight the rest of 100- wins in rank EX.
...Due to seed type's base mobility, high mobility wand build is probablly really hard.
Personally I found the recent rank C and EX gives easier wins. (Probably because all the new players...
) Unless you met someone who is also trying for 100 wins...
Hope this helps...
Hope this helps...
Re: Juvisy 100 wins
Thanks for the advice!
Actually while getting my A shinkis to S, i decided to try out my juvisy too.
juvisy + angel command body + cateye +machx2.
well, eat all the fishes in C and B, went Ex after getting A and now having a scary 48 win to 13 lose rate.
*Yes, nowadays class C and Ex seems to be fishes mostly (yay for battle masters~!) other than the occasional lv300 when my shinki is still 50+
Guess noone expect a sniper juvisy XD
Re: Juvisy 100 wins
fishes = food? those who cant chase my juvisy and lost with perfect.
- Maou Zenigame
- Shinkis owned: 14
Re: Juvisy 100 wins
Heh, I see that you have the same objective as me...
Got any Shinki codes you're not going to use? Then why not throw them my way? :3
